hydro boost system
Discussion in 'The Garage' started by KGsK5, Dec 30, 2006.
  1. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    went out to the junkyard today and found an 80s K30 2wd with a 6.2 in it. i want to pull the complete hydroboost system. what exactly do i need to get so that i am sure that i ahve the entire system? just booster and master cylinder? or is there more to it?
    thanks
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    technically the booster, hoses, and power steering pump, as it has two return lines. but you can T them after the ps gearbox if you need to.
  3. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I might have a hydro boost PS pump if you don't get it...
  4. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    thats where i scewed up. I got the hydro, m/c, and hoses, but at the time didn't realize the p/s pump was different.
    BTW....is the M/C actually different or are they the same as a regualr setup?
  5. k204dr
    Aug 27, 2004
    463
    TN
    the master cylinder is the same. you don't have to have to pump, just T your return line after the gearbox for the hydro to return to. thats how I have it setup on my stock scout ps pump. works just fine.
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I ran a "T" return line for about a year, and every once in a while, more often when it was cold out, the brake pedal would be slow to come back up after using the brakes.
    When I switched to TBI and installed a serpentine belt system I bought a remanned hydroboost pump/reservoir with the two return nipples (~$50) and haven't had the problem since.
    Others have reported similar problems when running a "T." Another bonus, the HB reservoir is bigger than the non-HB units.
    More info: http://coloradok5.com/forums/showthread.php?t=179887&highlight=hydroboost
