Hydro Boost
Discussion in 'The Garage' started by shoudabinacowboy, Sep 8, 2006.
  1. shoudabinacowboy
    shoudabinacowboy Registered Member
    Jul 26, 2005
    82
    Gold Bar, WA
    I have a friend who purchased one ton crew cab with hydroboost brakes. I think it's an '84. He is just using it for parts. If I want to put the hydro boost system into my '78 3/4 ton, which parts do I need? Do I need the steering box and pump? How about master cylinders? I have read that I need the brake pedal too. Any input would be cool. Thanks.
  2. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    For a best bet/ easy install get the booster, MC, hoses, pump and pedal.
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    You need:
    the pump
    the lines, 3 of them
    the master cylinder
    the booster
    the proprotioning valve
    the pedal assembly
    Thats how I would do it. I'd copy the factory in every way when it comes to brakes :)
    People do swaps without all these things and others have figuired out how to use what they have. Example - use a regular ps pump and tee in the third line. Even though it works, the psi wrong for that pump.
    Brake pedal is suppose to be different too. You can use the old one but I think the MS will bottom out so you better get the one ton assembly to have correct braking action. Or modify the current one...
  4. shoudabinacowboy
    Jul 26, 2005
    82
    Gold Bar, WA
    Ok sounds good. Thanks guys.
  5. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    hydroboost proprotioning valve
    do you need the proprotioning valve from a hb truck when swapping to hydroboost?
