Hydro clutch conversion, what else do I need?
Discussion in 'The Garage' started by ramses, Jul 25, 2006.
  1. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    Im trying to get the rest of the parts needed to do it now. I just want to make sure I have everything before I pull my motor. I have the bellhousing, slave and master cyllinders and lines, and resevoir. Now I need a clutch and flywheel for an 85-87 truck right? Do I need a new starter for the same year truck or will my starter work on the new flywheel? And I guess I need the pedal assembly out of the appropriate truck too, which I have access to, I jsut need to know what to get. I just need the actual pedal and the rod that hooks to it that goes into the master cyllinder right? If thats it then the parts list would be:
    Bellhousing
    Slave cyllinder
    Master cyillinder
    Hoses and lines
    Resevior
    Clutch
    Flywheel
    Pedal assembly
    Starter maybe?
    If im missing anything let me know, I think ive thought of everything though. As far as the swap goes, my only questions are how and where to mount the master cyllinder and clutch pedal.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well you dont need a new starter...
    but yeah you got clutch.. but pressure plate and throwout bearing are needed....
    also the clutch fork...
    think that is it .....:crazy:
  3. ramses
    Jul 2, 2004
    238
    West Virginia
    So I have everything on my list except the clutch fork? Can anyone give me some tips before I do the swap?
  4. ramses
    Jul 2, 2004
    238
    West Virginia
    Anybody?
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    what kind of tips do you want?
    need a tranny jack to remove the tranny and xfer....
    swap bellhousing...
    drop steering column
    unbolt brake booster
    remove the brake pedal assembly
    replace with hydro setup....
    put back together
  6. ramses
    Jul 2, 2004
    238
    West Virginia
    Should I pull the motor or take out the tranny and transfer? I was gonna pull the motor to put some new seals in it but I might just wait until I get my 400 built and not worry about that. I have to remove the brake pedal assembly and booster? I wasnt aware of that.
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    depends on how you want to do it....
    really easy to just pull the tranny and xfer..
    remove dshafts...
    4 bolts on xfer case cross member
    4 or 5 bolts on tranny to motor....
    then she will just slide out...
    remember to use a tranny jack or something as this sucker is going to be heavy.......
