hydro clutch in a 79
Discussion in 'The Garage' started by 79diesel, Apr 16, 2007.
  1. 79diesel
    79diesel Registered Member
    Apr 16, 2007
    13
    Ontario, Canada
    I am putting a nv4500 into a 79 gmc sierra. It is replacing a th400. Does anyone have pictures or measurement of the location of the master cylinder in the 73-80 firewall? If not is it very hard to figure out? I dont want to be breaking pushrods.
    thanks
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    Pretty easy to figure out! Bolt the hydro pedals in, then push the little support rods up against the firewall on the inside and drill the holes out.
    Next, find a piece of cardboard, put a hole in the center for the pushrod, then trim it to make it the same shape / size as the master cylinder, put the peice of cardboard on your firewall, put bolts through the two holes you drilled earlier, then use a hole saw to drill out the center hole.
    Bolt the master on, and you're good to go!
  3. 79diesel
    Apr 16, 2007
    13
    Ontario, Canada
    so should the cluth pushrod sit level when the clutch is disengaged?
  4. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    what nv4500 year and bell housing are you using? as the 96 - up internal hydro throwout bearing style take a diffrent line. and the 95 - down use pass side external slave that will mod easy to your old 85-91 old body style master. but the pass side slave might give drive shaft problems.
    and the way the 85 - 91 master bolts on is diffrent than 88-up new bodys.
  5. sweetk30
    Nov 1, 2004
    25,536
    532
    to install like he said. if you use a 85 - 91 pedel assembly its easy. bolt it in and remove the 2 studs and spacers. then mark the holes on the support rods and drill out. this will be the bolt pattern you need for the master. then just punch the big center hole in the propor place with a simple hand made templete and use the 2 mounting holes as a line up gide.
    thats basicly all i did for mine. but i had a 87 cab so the dimples were there. but real hard to see under the under coating.
  6. 79diesel
    Apr 16, 2007
    13
    Ontario, Canada
    I am using a 98 dodge nv4500. I am doing a 6bt cummins swap. This is a 2wd truck so driveshaft clearance wont be an issue. (yes i know this isnt the place for a 2wd but you guys seem to be the only ones that know anything about this stuff lol)
    So i will have issues modifying the line new style line to the gm master?
  7. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    well i'm currently lookin into this myself. while lookin at my friend truck (87) it looked easy enough. but lookin at mine (79) where the clutch rod comes through next to the fuse box it has a lone set of wires. don't know if yours is like this but looked as though the wires might be in the way. idk just a thought
  8. 79diesel
    Apr 16, 2007
    13
    Ontario, Canada
    well it does look like it could be close to the fuse box but other then that there doesnt seem to be anything in the way that couldnt easily be repositioned.
  9. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    oh well i just had bout 5 wires coming out between the fuse box and something else. they had it sealed with something. they may have just routed them themselves. thanks though
  10. 79diesel
    Apr 16, 2007
    13
    Ontario, Canada
    oh yeah i think i know the ones...if they are, they are mounted by the steering column plate and if you undo the holder you can move them out of the way.
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    here is the measurments i took off a 85 k5 with factory hydro, been working in my truck just fine.
  12. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    I used that map for my 81 Jimmy and it worked great. I swapped in an NV4500/203/205 and the hydro clutch stuff.
    Rene
  13. 79diesel
    Apr 16, 2007
    13
    Ontario, Canada
    awesome thanks
  14. 79diesel
    Apr 16, 2007
    13
    Ontario, Canada
    are the measurements the same for the 73-80 firewalls? i.e. does the wiper motor mount in the same location?
  15. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    look in my pics on the supersize75k5 link in my sig below, there is some pics, one of which shows a aftermartket master in the factory spot, shows some detailed pics.
  16. Russell
    Jun 23, 2000
    7,922
    333
    Yep, they are identical :)
  17. 79diesel
    Apr 16, 2007
    13
    Ontario, Canada
    alright thanks again
  18. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    i'll try and take a pic and post it. hard to explain. i know the ones you're talkin bout though
