Hydro Clutch Line?
Discussion in 'The Garage' started by PsychoticDeadGuy, Mar 16, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I am trying to finish up my manual tranny swap. I decided to go with a floor mounted pedal and master cylinder, but the master cylinder that I got uses a nipple type fitting on the end instead of a AN style fitting. What should I do? Could I get the stock line and turn it backwars and cut the end off of the rubber end and just clamp it on my master cylinder? I got it off of a Bronco (Furd) and it used a hard plastic line. What should I do?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    Why not use a GM truck master / slave cylinder?
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    I couldnt find one. I got this one for free.
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I got mine made at a local shop with half the stock metal hose and 10,000 psi flexhose.
  5. PsychoticDeadGuy
    Jan 8, 2005
    753
    alright, does anyone know if the threads in the master cylinder are the same as the ones in the stock slave cylinder for the line? I want to hopefully just run the metal part to the slave and use a clamp on the rubber part, master side.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    My setup uses a Toyota Landcruzer Slave & GM Master.
    I used a steel flex hose from Earls, then I used fittings that convert to AN-3 for the hose to work. You can see on my master I had to use two fittings to get it to AN-3.
    Find out what your threads are and you should beable to find a fitting arangement to get a AN line to work.
    Good Luck
    Burt
