Hydro Clutch linkage Q - pivot rod weld/bush
Discussion in 'The Garage' started by rcamacho, Feb 26, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    The rod that connects the clutch MC to the pedal is worn at the pedal side (small 1/2" pivot pin). Both the rod and the pivot are significantly worn. There appears to be no bushing present or in the design.
    I'm thinking of just welding some material to the rod and pivot and grinding to fit.
    Thoughts?
  2. dyeager535
    26,979
    I don't see why that wouldn't work.
    I'm with you that there is no bushing there, just the stud, the hole in the rod, and the clip that holds the rod on the stud.
    Never seen/heard of one worn like you describe, sounds like a fluke.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Well I finally got around to welding up some material on the clutch MC rod to compensate for the wear. It worked like a charm.
    Now one of these days I'll get around to the R&R/weld on the pedal pivot. I'm glad I picked up a welder after all... :)
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    Any pic's? It's looking like I'll have to fab that rod up for my set-up as it's the only piece i don't have...:doah: :doah:
    Rene
  5. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Bronze bushings work well too but it depends on how deep the wear groove is.
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    bushed..
    I had a brake pedal that was sloppy on its pivot,on one truck I had..it had a thin plastic bushing that was spiral shaped,it was trashed..I found that a peice of 1/2"copper tubing fit good on the pin,and all I had to do was taper the tubing a bit on a grinding wheel,and I was able to tap it right in the pivot bracket with a hammer,using a 1/2" bolt as a driver..I thought of putting a grease fitting in it,but decided it was not worth it..I just greased it good before re-assembly..no more floppy,sqquueeaky brake pedal!..:D
