Hydro Clutch MC Rod removal
Discussion in 'The Garage' started by rcamacho, Mar 14, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I need to add some material to the rod due to wear. How the heck do I remove it from the clutch mc? The pedal end was easy.
  2. rcamacho
    Jul 1, 2004
    1,324
    WA
    Looks like it's retained by a snap ring and disassembly of the mc is required.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Yes it is
  4. dyeager535
    26,979
    Watch it after you take it apart though...I had a brand new one that was leaking through the end there, made short work of the paint on the inside of the firewall.
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hmmm I didn't think it was removable without destroying the seal?
    I would get a new one and start from scratch...I hate doing things twice:D
  6. dyeager535
    26,979
    IIRC there is nothing there but the rubber boot that "clips" onto the outside of the master, and the seal on the piston. Probably need to be careful re-installing the piston past the snap ring groove, and you are right, if it's old, it may be a better idea to just replace it.
    I didn't notice mine was leaking for months. It was an extremely slow "leak" and I never felt it in the pedal.
