Hydro Clutch mounting?
Discussion in 'The Garage' started by PsychoticDeadGuy, Apr 4, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I have read that when doing the manual tranny swap, there are some dimples that need to be drilled out for the master cylinder, where are these dimples? Could someone post a pic of where to mount the cylinder?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Don't know anything about no dimples. My C10 has hydro clutch from factory, I can snap a pic in the am if someone doesn't beat me to it. Its snowing/sleeting outside right now, no way I'm going out there now just for you!
  3. dyeager535
    26,977
    The pedals somewhat give you an idea where they need to be, if this is for your '87, IIRC they are already on the firewall, just not drilled out.
    If you've got the black plastic shielding on the engine side of the firewall, you may have to remove it to see.
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Off the right side (towards the fender) of the wiper motor is a bracket the MC bolts to. It sounds like the holes just aren't drilled if the truck didn't come with a manual.
  5. dyeager535
    26,977
    That is correct. The studs the MC bolt to are part of the pedal assembly, which aren't present on the auto trans trucks.
    All I remember having to take some time doing was locating the hole in the firewall for the MC, which was pretty easy once the holes were drilled for the studs to pass through.
  6. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    in my 89 the dimples were at the right top edge of the fuse box you may have to pull down the carpet a bit to see them.
  7. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    if your truck is pre hydro clutch they will not be there only 85 up I think.
  8. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    yep i think you are right 85 and up :D
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    pic of my 1985 setup while still in the parts truck.... only pic I have...
    on my 1982 cab I have a plastic inner well on the firewall..... it had a O where I had to drill out for the master cylinder..... the resivour had its own bracket that went to the wiper motor
