Hydro Clutch Parts, swapability???
Discussion in 'The Garage' started by Poohbair, Dec 1, 2003.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Will hydro clutch parts (master cyl, reservoir, pressure hose, and clutch pedals) off of an 88 chevy work on a 79? I know the body styles are different, but what about the parts?
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Im curious also
    btt......
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I don't see why not, would be custom work to mount it all, might be better off making some other pedal setup.
  4. dyeager535
    26,979
    I'd have to say that at least the master cylinder is different. S-10 setups are also pretty similar, but since the pedal to firewall difference seems to have changed between the S-10 and our trucks, I'd imagine the '88+ full size body also changed that dimension.
    FWIW the aftermarket master cylinder I bought has an adjustable pushrod. I have a feeling* this is so the same piece can be used on an S-10 or other similar application) and my truck, but didn't check it out further. Factory ones I've seen are not adjustable.
