hydro clutch problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by odee1, Mar 17, 2004.
  1. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    I'm working on putting a nv4500 into my 80 model dually that I tow my dragcar and jeep with. I have factory bellhousing,slave,m/c combination on it for a 92 model. I mounted the m/c to the firewall where I measured off of a 85 that had factory hydro setup. My pedal is really hard to push. Could I still have air in the system or do I have the m/c mounted wrong and not getting enough leverage out of the pedal?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What pedal are you using?
  3. odee1
    Feb 27, 2004
    50
    I used my stock linkage type pedal. I have a hydro pedal setup to use if I have to just got to get m/c that fits with it. Could I have the m/c mounted to low on the fire wall? With that I guess I don't have enough leverage?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's your problem right there. Rod is probably mounted too high, or it's at an angle where it is binding.
  5. odee1
    Feb 27, 2004
    50
    thanks man I'm fixing to go out into the shop right now and swap in a set of factory hyrdo pedals and matching m/c and see what happens
  6. odee1
    Feb 27, 2004
    50
    put the hydro pedals in last night and finally got the clutch bleed out. It works like it should now, I had the m/c in the right place the pushrod on the pedal was mounted to low.
