hydro clutch problems help me info added with pics
Discussion in 'The Garage' started by sweetk30, Dec 19, 2006.
  1. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    i have swaped a 79 mech system out for a 87 hydro system. i fired up the truck and it sounded like the motor wanted to blow up. found the older style clutch pressure plate was hitting the fork. now i have to pull all again and swap to a 87 style clutch. what the hell ??? is there something i have missed ?
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah i have always heard that the mech forks are diff than the hydro ones. i never knew what it caused though. im using a hydro fork with a mech setup:confused:
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what style pressure plate is on it, diaphram or 3 finger? never heard of the pressure plate hitting the fork with either style.
    the mechanical clutch fork is stepped foward. the hydro fork is flat in comparison. with the hydro fork on the mech step, you just need a longer rod from the z bar to the fork.
  4. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    that's what i figured, cuz i had to find some obscure ass pushrod to operate my setup:haha:
    so the mech fork is stepped forward inside the BH as well?
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Its just bent some to make up the differance...
  6. sweetk30
    Nov 1, 2004
    25,554
    547
    i looked at napa online and the style clutch pressure plate. it looks like 3 finger and it was working great on the old mech system so i left it.
    i got a used hydro bell and master fluid resivor and line. then new hydro fork dealer and new pivot ball dealer and new master and slave . blead all out. had pedel. then it was gone next day. so far i have found bad slave. bleader hole not made 100% and now broken. possible master as i dont get any real flow out of hose.
    i looked in bell boot hose with boot out and the fork is riding on the pressure plate. its cliped on bearing fine and on piviot ball fine.
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    do you have the right bearing? i know they are longer on the 3 finger than the diaphram style.
    inside the bell should be the same as far as the fork goes. if it didn't hit on the mech, it shouldn't hit on the hydro.
  8. sweetk30
    Nov 1, 2004
    25,554
    547
    well i reused the bearing for the old stuff as it was good and no noises. and the old stuff didnt hit like this. i checked napa #s and it called for stock part #s the same bearing in 79 as in 85-87 hydros .
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    hmmm, where exactly on the fork is it hitting?
    you said you got a new pivot ball. could it be the wrong part and too long?
  10. sweetk30
    Nov 1, 2004
    25,554
    547
    well found out 100% not to run 3 finger with hydro parts. need the thinner stock style pressure plate. 3 finger to tall and hits the fork.
    took pics of the forks together and wow what a diffrence. also measured the bell housing to top of piviot ball stud. both same distance in to bell.
  11. TC4x4
    TC4x4 1/2 ton status
    Sep 12, 2006
    831
    Michigan
    what is a hydro fork??? (Wanting to learn a little)
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It is a clutch for that is used with the hydraulic slave cylinder to actuate the clutch vice a mechanical linkage.
    Ira
  13. sweetk30
    Nov 1, 2004
    25,554
    547
    we have clutch now. :bow: :wink1: :D
    the 3 finger pressure plate is 1" taller than stock style plate. all new clutch kit with cut/finished flywheel is installed and driven with no problems and of noises. i have room to fit my finger in the space of the fork to plate now.
    hope this info helps someone else out. i now have learned the hard way about 150 bucks worth with my shop price discounts on parts that hydro dont liky 3 finger style. :eek1: :doah: :D
  14. sweetk30
    Nov 1, 2004
    25,554
    547
    had a small issue with clutch pedel freeplay and working. best way i found was gravity blead it. close it and let it sit over night. now i have perfect clutch pedal.
  15. sweetk30
    Nov 1, 2004
    25,554
    547
    well i have tryed to drive it a few times. today i needed gas and wanted to drive it to the station. well 1/2 way there no clutch pedel. then 1/2 clutch pedel. then if it site more than 2 min i have nice firm clutch pedel. then after 1-2 uses no real pedel anymore.
    what the heck is going on with this hydro setup? i have vac blead it and gravity blead it.
    what am i doing wrong. or missing.
  16. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sounds like your getting air into the master cylinder either threw the line from the reservoir, or the little oring at the plastic fitting going into the MC.
    it could also be a bad MC, but it doesn't sound like mine when mine went out. i had nothing, it would pump up and hold it, by the end of the day, my leg was killing me from all the pumping to get the clutch to disenguage so i could stop or go(playing on the dunes).
  17. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    When you vacuum bleed the system you also have to do it backwards... put a line on the bleeder screw on the slave into a clean bottle of brake fluid then attach the vaccum bleeder to the input on the master. If you try to go the other direction with the vaccum bleeder on the bleeder screw you never get all the air out of the master.
