hydro clutch question....GOT HER FIGURED OUT
Discussion in 'The Garage' started by 55Willy, Jul 15, 2003.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm converting to hydro clutch and with the placement of the slave I have a few questions.
    1) how much of the rod should stick out?
    2) which way does the bleeder point?
    3) how close to the header is save?
    4) how much travel is needed?
    **Thanks I got her figured out and should have pics by the end of the week (new roll of film)***
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Re: hydro clutch question..wheres the slave go???
    1. 3" should be good
    2. Up
    3. 1 1/2"
    4. Enough to disengage clutch, how much did it move before?
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    damn. I'm not even close to getting any of those measurements to work,LOL
    and as for how much did it move before...I dunno. /forums/images/graemlins/confused.gif
    any one have any pics of thier hydro set up from the bottom and from the top...or any pics of that matter.
    I basicly need a reference point to go off of (like the block/bellhousing split)
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    If You want You could mount the slave under the cab, if the rod were long enough, and did'nt fall out, and the hose were long enough to reach.
    It does'nt have to be on the bellhousing. /forums/images/graemlins/grin.gif
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    The one I have is a push style not a pull.
    I can mount it in the normal GM fashion but it would be about 1/2" away from the header, even though the slave has a heat shield on it, I know that is too close for comfort. I don't need to be boiling brake fluid.
    maybe I should hit up the local speed shop and grab a pull style.?????
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Add a heat sheild between the two. Just a piece of tin, or light flat plate, will help insulate it, airflow around both side's of the plate. Couple of hose clamp's on the header, forward and rearward of the slave cylinder?
  7. dyeager535
    26,982
    191
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    thats perfect!!!! /forums/images/graemlins/thumb.gif
