Hydro clutch setup firewall pics needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by arq, Sep 29, 2004.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    anyone have any pics of the hydro clutch master cylinder mounted onthe firewall. I am converting an 86 auto to a manual and need to know where to cut the hole.
    thanks,
    ARQ.
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    If I am not mistaken, there is dimples where the bolt holes should go.
    Look next to the wire harnes and see if they are there. If they are, it should be easy to figuire out.
    If I can find my digital camera, I'll take a pic of my firewall so you can see what the hole looks like (mine was factory 465 and I converted it to th400)
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    I'll check it out. there is some kind of mud or goo on the firewall. i'll have to scrape it off.
    /forums/images/graemlins/waytogo.gif
    thanks,
    ARQ.
  4. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    discovered something interesting that i never paid any attention to before when i was pulling my last hydro setup out of the truck at the junkyard, the support rods are actually the same studs that hold the master cylinder int, and there are dimples in the firewall for it.
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Would that be the speedo cable right next to the holes??
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    got them thanks, actually there are several dimples, i made an extra hole for ventilation /forums/images/graemlins/whistling.gif it gets kinda hot there. I made a paper template and kinda moved it around the firewall where i would think the mstcyl would go. I was wrong the first time i figured that out after i tried putting in the support braket. i cleaned the firewall a bit more and saw that there were like 6 dimples. important thing to remember is that the intake thingy from the resovoir tank has to sit right on top of the mstcyl.
    thanks for the pic, /forums/images/graemlins/thumb.gif
    ARQ.
