Hydro-clutch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mojo-jojo, Nov 10, 2004.
  1. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    OK guys question, I want to change the turbo 400 and 203 out of my 89 sub 4x4 to my old 465 205. I want to go hydro because of a weak knee. I can get all the parts out of an 89 2wd pick up. Minus the pedal assembly will all the other parts work. Thanks for all your help
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes. a 465 is a 465 in the clutch department as far as I have ever heard. 2wd and 4wd doesn't matter.
    Harley
  3. mojo-jojo
    Sep 26, 2003
    101
    PGH PA
    I not concerned about the trans and t-case, I need to know if the master,slave cylinder and bell housing will work. I have all the mechanical stuff, but need to go hydro for ease of operation. I had the mechanical stuff in there but my knee can't take the strain. So I converted to the auto, been that way about 2 years. I just don't like it.
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    89 2wd is a different trans., the bellhousing is integral to the trans case
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    IIRC the 88+ trucks put the slave cylinder on the passenger side. the pedals are totally different as well.
  6. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    You will most likely need the bell housing from the donor truck also.
