Hydro Clutch?
Discussion in 'The Garage' started by Brady, Oct 25, 2002.
  1. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Ok.I am building a '79CJ-5(I know,I know!).Anyway I put a SB Chevy in with a 465 and 205.I want to run a Hydro clutch,I assume 85-87 Chevy will work,right?How does the slave cylinder bolt to the trans in these rigs.Is the slave a pusher or puller?Thanks for any info. Brady
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    It takes a special bell housing but I believe it is set up to push the lever that actuates the clutch. unless you get the kind that is internal to the bellhousing which can make a mess out of the clutch in the event of a failure and is not desireable.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Kenny is correct...You need the hydro bellhousing or an adapter from AA...ZThe master cyl. mounts on the firewall and the slave mounts on the bell in such a way that the fluid enters from the front of the vehile and the pushrod that activates the clutch fork... The slave is held in the bell by two threaded stud from the slave and held on bu 2 nuts...pretty damn simply hydraulic system and it is soo sweet..The pedal feel on my K5 is amazing..it is so light, even with the Centerforce DF clutch...
    Chris
  4. Brady
    May 6, 2000
    628
    Parachute,Co
    Fortcollinsram,Which do you have and do you have any pics.I was planning on building a bracket myself.Thanks Brady /forums/images/graemlins/usaflag.gif
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I got picked up the hydro bellhousing along with the pedal assemble...I don't have pics, but MJ has some of the master mount and a diagram of the bellhousing ans slave mount I believe...PM him and he can provide the link...You could probably pick up the bellhousing at a yard for like 15 bucks or so...
    Chris
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    so what about the pedals? will the mech. pedals work or do ya have to have the hydro ones?
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    use all the factory hydro parts, it is much easier and they are cheap at a wreckers
  8. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Um...I think the mech. ones wil work...but you will have to drill a hole in the proper location of the master cylinder pushrod...If you send me a PM tomorrow, I will try to get under there and measure it for you...But the hole has to be the correct distance from the pivot so the pedal travel to clutch fork travel ratio stays within spec...otherwise, you could find yourself with leaky MC's and SC's and or a clutch that doesn't release all the way...
    Chris
  9. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    thanks mj. will do fortcollinsram
  10. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here's a pic of the 454 that is going in my 69. This engine/hydraulic setup came out of an 89 1 ton.
  11. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    It is much easier with Hydraulic pedals. It is possible with regular pedals. The hard part is lining up the inclination of the master cylinder to the arc of the pedal travel. If it is off a little bit, you will ruin your master cylinder.
    I have the hydraulic pedals on my '73. I have setup the hydro clutch on my friends '72. I got the arc right, but the through is REALLY short (and heavy) on his '72 Blazer.
  12. I to am looking at a hydro set up and think that the best way for me is to find a donor truck(possibly from a scrap yard). So what trucks do I start looking for, do they have to have a 465 and what years came with the correct set up.
  13. Nice setup but I have some brand new stamp steel crome vavle covers that would look good on that big block and I'll make you a good deal on them /forums/images/graemlins/cool.gif. I ran into a set of factory aluminum covers befor I put the crome on.
