hydro master cylinder mounting location?
Discussion in 'The Garage' started by backyardbuilt, Apr 8, 2004.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Anyone have a pic of the firewall where it goes. I can't seem to find the hole where it goes. Thanks
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Pm me your addy I will send you a template that you can put on the firewall and cut one time...lol
    I have one to go out for andy.
    Unless you have a truck to copy it from (that is what I did) then just placed it on the firewall and cut it out..That way it is in the right spot.. /forums/images/graemlins/waytogo.gif
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    I am sure you know this but placement is 100% critical our the MC will leak in a very fast time span..
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    on Tim's truck there was a hole in the firewall there already, and everything appears to have lined up correctly. my 86 has the same hole that i plan on using when i install mine.
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I pm'ed tim about it, I think I found the hole. I used it to run a bunch of wires thru, lol. Guess I will have to move them.
  6. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Um NO...lol
    If it is a 85-87 cab then the hole that the wires go though isnt the right hole....It is close but no cigar..IIRC the hole you are thinking of has the cruise or wires like that in the hole..But that isnt the right MC hole.. /forums/images/graemlins/weld.gif
  7. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I have a 77 cab I put the wires there when I did the cab swap. I think it was the speedo cable hole originally. Just send me the template and I'll be fine, lol.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Um NO...lol
    ok, so where is it?
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's exactly how mine was. Had to move the wires. This hole was plugged from the factory IIRC.
    Right hole or wrong, the master certainly hooked up there and it works beautifully with no binding.
    My cab is an 84.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In addition to mount the master anywhere else we would have had to weld up the firewall. There are two holes in it and if neither would work there is no way you could drill another and still have a solid enough firewall to mount the master.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    good point Tim, and i think had we used the other hole, there would've been interference between the firewall boot for the column, and the MC body. of course, that might not be a problem for you, since you've got that extra 3/8" hole in the firewall. /forums/images/graemlins/whistling.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The issue that I feel we might have had is that the rod for the master wouldn't reach the pedal unless it was really close.
  13. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I went ahead and stuck it in there to see what it looked like and it mounted to the peddles exactly the way it should, hell it almost went on the pedal post by itself when I went to check it.
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it gets tricky when 1/2 the posters are talking about the newer cab
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    So the hole that everyone is referring to in the 85-87 cab is a no go or what?
