hydro pedal rods
Discussion in 'The Garage' started by NoSmog73, Jan 22, 2004.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Since the search is down...Anyone have a good pic of the rods where they mount on the firewall from the inside..Thanks Mike
    The one that you can see is the shorter rod..Sorry
    I have this one I think in the right spot...But the other one is pissing me off...( I have the shorter rod in but the longer one is giving me placement problems... [​IMG]
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    whatr i did was press out the studs, then loosen the top bolts and see where they sit naturaly. i drilled the holes and then put the studs back in and tightened everything up.
    everything went together fine that way and i only had to oblong one hole by 8th inch or so. its in my 74 so the firewll was not set up for it.
    grant
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Thanks grant...BTW those doors are close to going on...lol
    Anyway I went to PNP and thankfully the same truck was there so I traced a template and now have one for future...lol
    Got home lined it up and drilled it and slapped it in hooked it up...now that hurdle is over...lol
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    ya knwo what.. i think i also had a template.... but i used the torch to cut it off the truck i got everything else from....
    i forgot about that...
    no, i didnt use it as a template.. i used it as a backing plate to strengthen up the fire wall.
    Grant
