Hydro ram limiting
Discussion in 'The Garage' started by Citizen Rider, Jun 22, 2006.
  1. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I was told that i will need to put a stop inside the PSC 1.75x8 ram.
    Does anyone have or can give instructions on doing this? Pics would be awesome also. Just dont wanna mess it up.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Do you have highsteer? D60, 10Bolt, D44, IFS????
  3. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Will be a D60, crossover with stock location tie rod.
  4. readymix
    May 30, 2004
    6,706
    26
    Should not need to do anything to it then. I will be getting the 1.5 x 8 PSC ram soon, and have heard that 8" is just right
  5. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    I have also heard this, but ive been told that without the limiting it will crack and break the knuckles by over extending.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I only heard that a 8" ram was too long with revearse high steer and was perfect for regular tie rod placement. Maybe I am wrong, would like to know an answer cause like readymix I too am gathering parts for hydro assist.
    Ira
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Mine is a 8" and it is perfect.
    You wont break knuckles with hydro assist.
    Why are you getting a new ram anyways?
  8. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Well mostly preference but when i get 20% off PSC stuff, it makes the deal even better.
  9. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I'll be running ORD hi-steer on my 60. I was thinking the stop went on the rod between the cylinder and the end .. is that not correct?
  10. readymix
    May 30, 2004
    6,706
    26
    Yes. On the inside of the ram, not the outside.
  11. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    That's the impression I was getting. But i was thinking outside (although I didn't really like th eidea of that). I guess it would help if I had my ram already ;) . I'll probably be buying a rocklogic ram this week or so.
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    It can go on the outside, just going to take a different style stop.
  13. readymix
    May 30, 2004
    6,706
    26
    And it will grind dirt and crap into it everytime the ram retracts into the stop
  14. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I think I'd rather have it inside for many reasons. I didn't want to buy a 6" stroke in the event that my set up changes in the future I could save myself from buying another ram. This way I can just remove the stop.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    No it wont, they make special stops that have a recess in them to allow for the gunk, same kind that full hydro rams use.
  16. readymix
    May 30, 2004
    6,706
    26
    Cool. I have never seen those before. Got a link?
  17. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If your tie rod is in factory location the 8" ram is what you'll need without any limiting. Now if you go hi steer then you'll need to limit travel by installing a spacer inside the ram. Just remove the heim on the shaft, then using a spanner wrench remove the cover and install the proper thickness spacer and put the cover back on.
  18. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  19. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    That looks like it would be fine for a double ended ram with full hydro but not for a single shaft hydro assist ram as it would surely break the heim off the end.
  20. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    ive got the PSC 8'' ram on crossover with stock tie rod location also and its perfect.
