Hydro ram lines
Discussion in 'The Garage' started by 4X4HIGH, Jul 20, 2006.
  1. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Which line goes where on the ram to steering box? If anyone could tell me the position of the line from the bore side of the ram (not the shaft side) to which position on the steering box. Does it go to the spool valve side or the long oil passage down to the end of the steering box side.
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Just hook it up and turn the wheel. If the tires turns opposite the way you turn the steering wheel, or otherwise doesn't work right, swap the lines around. Thats what I did. Hooked it up backwards the first time. Swaped the lines at the ram and it worked the way it should.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    same with mine. only way to find out is to hook it up and turn
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I just looked at mine:
    The top fitting on the steering box goes to the pumpkin side of the ram
    The bottom fitting on the box goes to the knuckle-side of the ram
    Mike
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Thanks guys, hydro all done and working flawlessly. :thumb:
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Do you find it a bit slow for street driving? Mine was a liability on the street so I've taken it off. Still not sure if I had a problem or if that's the way it is.
  7. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Mine's very streetable. The only time I've noticed it being slow was when I went to (purposely) powerslide it on some gravel and when i went to correct the slide it took longer than I expected for the wheels to turn. But since I don't race the truck this is not an issue.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Ram bore size & pump volume are both huge factors in this. If you want to put it back on look into either a smaller ram bore or increasing the pump's volume.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I have no problems with street driving. Took it out for a cruise last night and made some real quick turns and it works perfectly. I do have the 1.5" bore ram which i've heard is really the only ram that works fast enough for street driving. I still have a factory P/S pump without any mods. I will soon do the mods to the pump to bring up the pressure a bit and see what that does. I don't know that i can say it makes the truck any easier to turn but it definately tightened up my steering a bunch. I'm sure once the pump mods are done it will steer with my pinky like i've seen in the past.
  10. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    My buddy showed me how to do the pump mod. It's very easy to do! I had to re do it because the pump we did it to doesn't fit the bracket for my engine so I had to re-do it to my existing pump.
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, I did the pump mods and I have 1 1//2" ram but when I turned out of a tight side road I couldn't straighten up quick enough, mounted the sidewalk and nearly took out a bus stop!:o It skeered me!!:D
  12. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Can the pump mods be done while the pump is still mounted on the engine??
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Usually yes but it's a pain to get to.
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If that happened, something is wrong. Is everything new?
  15. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yep, everything new, even the pump! Steer slowly and it's fine, but turn in a hurry and ....scary!
