hydro ram mounting
Discussion in 'The Garage' started by 89Burben, Apr 13, 2007.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    got a hydro ram, just need to decide where to mount it with my high steer setup.
    1. weld to cast housing???
    2. make up some 1/2" spring plates with an extension on the drivers side to mount the ram to the plate....but would it move?
    3. weld to diff cover (stock) 1/8" thick
    4. get a rock ring or diff cover 1/4" and weld to that
    what do you guys think?
    any other suggestions or ideas would be appreciated:wink1: pics would help
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    :D
    And no the plate doesnt move,bend u bolts,or kill the center pin like some will say :D And I stole the idea from Greg72 :bow:
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I would get a double arm for the driver side knuckle and mount the ram to that, on top and behind the axle. You would have to weld a mount to the top of the axle housing.
    Doing this utilizes the rams power because it is not mounted to the tie rod.
    The steering box would be turning the passenger knuckle and the ram would turn driver side knuckle.
    Do not mount anything to the stock cover.
  4. 89Burben
    Jan 3, 2005
    98
    CT
    yeah, i was leaning mostly towards the spring plate idea, i have a welder and a plasma that will cut 2" so i can cut that half inch real nice.....
    this is a good idea, but i already have nice ORD arms and would rather not spend any more $$. thanks for the replies though
    why not just to the stock cover? u think it will get crunched like a soda can ? he he :D
  5. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Great reference pic :D !!
