Hydro SalveCylinder Bracket photosEDIT**This is the WRONG Bracket***>>>
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Burt4x4, Jan 11, 2004.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The bracket, the tapped holes are for the slave cylinder it self.
    See the top mounting bolt
    See the relation to the manual likage
    I will post up later one when it is together /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
    Mounting bolts with bracket moved out of the way.
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Re: Hydro SalveCylinder Bracket photos>>>
    Did you make that bracket?
    If so,you didn't happen to make a template,did you?
    Looks good /forums/images/graemlins/thumb.gif
  3. Burt4x4
    6,854
    No I can't take the credit on that one, Advanced Adapter sells it for 30 bucks /forums/images/graemlins/thumb.gif This one is setup to use a Land Cruzer slave or a 60's GM slavecylinder.
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    That is awesome! What about the master? And the pedals?
  5. Burt4x4
    6,854
    Nothing on them yet? I will probly get a GM master and drill a hole in my current clutch pedal to make it work. I have heard of folks swaping out the pedal assy. but I want to keep my pedals cuz I gots welded on mud grippers /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  6. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Lemme know dude.
  7. Burt4x4
    6,854
    Hey guys just wanted to give you all an update.....
    Turns out this bracket from Advance Adapters is the wrong one. They sent me the wrong one. The part number for this one was one digit off from the one they should have sent me. I will be reciving the correct slave mounting bracket sometime next week and will update you all with a pic!
    Just wanted to make sure this post was corrected for future use.... /forums/images/graemlins/thumb.gif
    Have a GREAT weekend /forums/images/graemlins/peace.gif /forums/images/graemlins/waytogo.gif
  8. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    When I installed my hydraulic clutch I just used my pedals and used a clevis pin and end rod to attach to the pedal. Just takes a little measuring to figure out where to attachit so you get the right amount of rod travel and make sure your pedal cycles without binding the rod. I have a post about two months old on installing hydroboost and a hydraulic clutch that shows pics of how I installed the rods to the pedals. I'm on my slow home computer so I can't find it for you right now. It is either in this forum or the Garage.
    Bummer they sent you the wrong bracket. I hate it when I am working on something and get thrown of track.
