Hydro Sm465
Discussion in 'The Garage' started by 84CUCV, May 11, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Come to think of it can i use my steel housing? I know there is a newer one, but i think its weaker. Tell me if i am wrong.
    mike
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Are you talking about an aftermarket scatter shield bell housing or a GM cast iron housing ?
    If you are talking about the GM 1972 and older cast iron bell than you can not use the 1985 and up slave . Check out Advance Adapters for a bracket that will let you use a Land Cruiser slave on your GM bell housing.
    There is a later model "P" series Van cast iron bell housing that has a provision for a bolt on slave cylinder if you can locate one and use all GM parts .
    HTH , Tom
  3. dyeager535
    26,979
    Hydraulic bellhousings (at least for our trucks) are all aluminum.
    Used on everything from 6 cylinders to 454's, short of the problems one or two people have expressed on here, the aluminum ones don't seem to be inherently weak.
    I believe Novak or advanced adapters sells an adapter bracket, if you were set on cast iron bellhousing (that's the other stock material AFAIK) adapter is your only bet I imagine.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    So cant i just weld on a tab or something for this to mount?
    mike
