hydroboost and pedal play?
Discussion in 'The Garage' started by yunit, Jul 9, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    what did you guys do to get rid of the slop in the pedal, just lengthen the rod off of the pedal?
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    talk to borrego. i think he lengthened it some and then just got used to the rest.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The hydrabooster has a larger diameter hole in the rod than the clutch pedal can fill. Shim the hole with a small bushing, slice of thin tubing or other item and all the play goes away. /forums/images/graemlins/thumb.gif
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    mine bolted right up with zero play... 81 k5 donor 85 1 ton military... had to play with power steering brackets and that was all
    cam
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    mike
    sorry i misqouted you on that one. its been a while
