Hydroboost and Ram Assist
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 18, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Couldn't find any posts by searching.
    Is hydroboost workable with WTO ram assist steering? Seems like one would need to T off the high pressure line and for the low pressure hose just connect them together at the pump.
    Stock output PS pump?
    What else?
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I am running WTO hydro and hydro boost w/38's. Matt warned me I would not have full assist but it works pretty well. I notice a lack of assist at times but not really a big deal. I have a stock replacement pump. I do want to try some of his tricks to get it better.
  3. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I just got my ram and pump back from WTO. I will be running the hydro assist with hydro boost, plus I am using the Milemarker Hydaulic winch. I had Matt do the modifications to a new pump. As soon as I get it all sorted out and hooked up I will let you know how it works. I am presently working on a larger remote resevoir.
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    How do you have it plumbed?
    Woudl you recommend getting a junkyard booster and lines or getting new and having hoses made?
    Any suggestions?
    Pic would be great if you have one.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you have that many things on it I would suggest you put another pump just for the hydraulic winch.
    That's what I am doing for mine when I get that winch.
    /forums/images/graemlins/thumb.gif
  6. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    I have been considering a seperate clutched pump for the winch or possible going to an Electric.
  7. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    I have it plumbed like OEM- pressure line from pump to hydrobooster, pressure line from booster to steering box and each have a return to pump. Then two lines out of box to ram. I got system out of 87 C&C truck. I had to replace booster (old one leaked) with Carquest rebuilt and replaced pressure hose from pump. Junkyard parts are OK. Just inspect hoses and ends for dryrot or missing O rings. Sorry, no digital camera.
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm running the full stock hydro boost and WTO hydro assist with 2" ram. The only thing I've done is modify the volume from the pump using the WTO mods. I still have trouble turning when hard on the brakes. I'm thinking about running dual remote res pumps. One dedicated to the hydro boost, the other to steering. The HB will be stock and the steering will have the volume mods. I think that will solve my problems...
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is the MM hydraulic winch any good?
    I bought their electric because I heard the hydro winch was sloooooooooooow. I think I'll be fine with the electric.
  10. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    The MM winches are great. Yes the Hydraulic is slow, but I am not competing in any timed events I am just wheeling. I like the added control of the slower line speed. I have used mine on the trails several times as well as one long day of very hard use moving a stuck mobile home and transport truck.
  11. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I really like my Warn 9000 electric.
    Easy hookup and classic durability.
    About the hydroboost - I think I'll check the jyards and see what they have. I need to the hydro brake booster and the lines...thats all, right?
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would use the MM hydraulic winch on a vehicle that will not stall, like diesel or FI and it will keep running as long as you want, will not overheat, or kill the batteries.
    On the other hand on a trail truck using a carbed gas engine I would go with an electric with a couple of good gel batteries in case you need it with a dead engine, that you can't do with the hydro...
