hydroboost bleeding help
Discussion in 'The Garage' started by the excuse, Jan 13, 2004.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    how do i bleed my hydroboost brakes. i think i might have gotten air into the system because i might have run out of fluid in the resivore. how do i bleed the brakes for this. i also broke the bleeder screw on the front passenger brake. it is still shut just broken off. does the pump need bleeding too?
  2. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    The brakes are separate from the booster. So they bleed just like any other brake system. To bleed the booster I think you just jack up the front of the truck and cycle the wheels back and forth as if you were bleeding a regular PS pump but that should only be necessary if you've opened the hydraulic system.
  3. the excuse
    Dec 9, 2003
    209
    san diego
    is there anything i can do about the broken bleeder on the front passenger caliper?
  4. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    You may be able to get it out with an EZ out type tool. If not you'll be replacing the calipers. They are really pretty cheap though. /forums/images/graemlins/thumb.gif
