Hydroboost conversion and ABS problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Sep 28, 2003.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I converted my 91 V2500 Suburban to Hydroboost brakes. I swapped in a 91 V3500 pump with 2 return lines and a 91 V3500 Hydroboost unit and master cylinder. The truck stops fine, but the rear ABS isn't working the way it should. On hard stops, they let the rears lock up. I'm assuming the Hydroboost and larger master are creating more pressure than the ABS unit was designed to handle. This is the old style ABS with the isolation / dump valve and an ABS ECU, no sensors at the wheels. I already have the 14 Bolt FF rear with the large 1 ton brakes and a Dana 60 front with 1 ton brakes. I'm thinking I need to ask a dealer if the ABS ECU or isolation / dump valve or even the combination valve are different between the 91 V2500 Burb and a 91 V3500 1 ton truck, and if so, start swapping them one at a time.
    Anyone have any experience with hydroboost / ABS swaps before I hand my credit card over to the GM parts guy.
    Thanks,
    Eric M.
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Eric, Check out this site-JIML'S brake paper.has a lot of info on hydroboost.....hope this helps
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what site is that? /forums/images/graemlins/confused.gif
  4. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ]just a site with a ton of info on brakes.................
  5. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Mudjunkie - Thanks,
    I did check out that site. They discussed Hydroboost, but not concerning a swap with ABS. Someone needs to tell the guys over there you don't have to buy all your Hydroboost parts from the dealer! You should see the numbers they were quoting for conversions /forums/images/graemlins/blush.gif
    Got any pics. of that 82 with the 540 and a 12-71 blower?
    Eric M.
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
  7. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    have a couple but not sure how to post them?
  8. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    MudJunkie,
    e-mail the pics. to me, I'll get them up somewhere.
    Eric M.
    eric@mannon.com
  9. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Eric, Forgot to mention talk to randy (r72k5 ) he knows alot about this and might be able to help..............
