Hydroboost help needed
Discussion in 'The Garage' started by trukman1, Oct 15, 2003.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Can anyone tell me the correct way to remove the rod that runs from the brake pedal into the rear of the hydroboost unit? Mine has a rubber "grommet" that presses into a "sleeve" and is hard and, short of burning it out, I'm not sure how to get it out. Any ideas? Thanks, trukman1 /forums/images/graemlins/confused.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    grab it with some vice grips?
  3. trukman1
    Mar 5, 2002
    129
    Ohio
    Tried that...pulled till I thought my guts were gonna pop out! No way that thing will budge and even tried a pen drill to cut it away since there's hardly any room between the two...nothing happening! I figure there has to be a trick to it but what? trukman1
  4. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    IF IF IF IF i Rember right romove the rubber gromet and you will find a small snap ring in the grooove remove snap ring and vola you should thn be able to pull the rod out
    just curious
    why are you removing anyways ???
    R
  5. T-ROY
    T-ROY 1/2 ton status
    Dec 3, 2002
    468
    Orchards, Wa
    I rebuild those things for a living. put the shaft into a vise and hit the body of the unit with a plastic dead bolw hammer. It will probably take a couple of shots, but it will come out.
    T-roy
  6. trukman1
    Mar 5, 2002
    129
    Ohio
    T-ROY, Thanks, that's just the kind of info I needed! Thanks again! trukman1
  7. trukman1
    Mar 5, 2002
    129
    Ohio
    BTW, Doctor4x4...Let's just say the 1-ton conversion got carried away!
