Hydroboost Master Cylinder
Discussion in 'The Garage' started by dan76k30, Mar 19, 2004.
  1. dan76k30
    dan76k30 Registered Member
    Feb 7, 2002
    6
    Denver,CO
    I know this has been hashed a few times, but I never found the answer. What master cylinder is recommended for a hydroboost setup w/ rear disks.
    I picked up one for a hydro and the hole on the piston is about 1" deep, but the rod on the hydro is flush to the edge. Wrong rod or what?
    So then I got a mastercyl. for a non-hydro K30 where it just has a dimple on the piston and should work with the (short?) rod on the hydro. I would like the larger resevoir of the one for hydro, but would like opinions... Thanks
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Talk to Randy (R72k5)He would know........
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you would be fine with disc drum one, you wont find a disc disc hydroboost m/c anyways and reven the disc drum oens are $$$$$$$$$$$4
    you would want ot get a 4 wheel disc combo valve though
    i just threw out a bendix hydro m/c a big one, damn
  4. dan76k30
    Feb 7, 2002
    6
    Denver,CO
    So do you think I should just go with the non-hydro master cylinder, and modify the proportioning valve? I can't remember the type of MC, it's not a Bendix. It has the round reservoirs, I was told it is for an 80 K30.
    Also, I noticed the fitting are the reverse of my old brake lines? Did they switch front/rear ports? Do most of you make up new brake lines from MC to Proportioning valve?
