Hydroboost pedal return spring?
Discussion in 'The Garage' started by dremu, Apr 30, 2006.
  1. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    So I notice that the brake pedal on hydroboost trucks has a spring to hold it up to the foot ... is that for mechanical reasons, i.e. will I wear out my hydro unit without one, or is it just to make the pedal "feel" right to people used to vacuum boost?
    Said another way, can I run without one and feel no ill effects?
    -- A
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I put a spring on mine because it was easier than adjusting the break light switch. With HB my pedal was low enough the brake lights stayed on all the time.
    Ira
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Same thing here, I saw the spring when i pulled it out but didnt give it much thought untill my lights were on all the time, I bought new springs but the damn things kept popping off so I adjusted the light switch.
  4. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I failed to grab the spring as well, so my lights stay on all the time. I just pull the pedal up with my foot after braking and it stays. Got to be a habit after awhile.
  5. sapper
    Jul 11, 2001
    3,052
    NoVa
    I did that for a day or two but what I really didnt like was having to use a bungee cord when it was parked to keep them off, just a little to trailer park so I adjusted the switch, it only took about 10 minutes, a slight PITA but works fine now.
  6. dremu
    Feb 27, 2000
    15,970
    462
    Followup: For those considering the hydroboost swap, grab the spring and hardware and do something, as I'm tired of my brake lights staying on and draining the battery :angry1: Adjusting the brake light switch helped some, but it's still fiddly... so I went out this morning and put a spring on it. That pedla has RETURN now, baybee!
    -- A
