Hydroboost ps pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1-tonmudder, Feb 23, 2006.
  1. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I have an 84 Mil Blazer that was a 6.2 diesel with the hydraboost.I am parting my truck to build the blazer and am going to use the 350 in place of the 6.2.What power steering pump are you guy's using.I know a non hydroboost pump wont work since it dont have the 3rd fitting on the back,and I have a hydro-pump from a 6cyl truck,but my brackets wont let the lines clear the block.So can I use the diesel pump with the gas brackets or will I have to find a pump off a gas motor with the hydro-boost.I have access to a set of BB ps brackets off a hydro pump,but I dont think they will work either.I will probably buy a new pump but want to know what brackets to use.Im sure this has been done 100 times but I'd like to hear from someone that knows so itll cut down on the trial and error.
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I've been using a non-hydro power steering pump for over a year.....A "T" in the return line makes it possible, although some have recently reported better results using 2 return line setup and reservoir. Mine has done OK, but I recently changed the return hose and now have a small kink reducing flow...I will address that this weekend.
    I have 3 different pumps in the garage, but use the one that fits the bracket.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I had to modify the bracket on my 350 to work with the Diesel PS pump. I think I am gonna get a pump for a 1-ton with a 350. The lines on the rez look like they will clear the frame a little better and also will fix the issues I had with the bracket. Only 1 of the 4 bolt holes lined up so I had to redrill the bracket and trim the bracket to clear the rez. All in all it is alittle bit of money but buy the HB pump for a gas motor.
    Ira
  4. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    You could just swap the reservoirs around to get the pump setup you need. That is what I have always done. I keep a couple of extra reservoirs around. From what I have seen the pump itself has always been the same, they just use different cans.
    Russ
  5. 1-tonmudder
    Apr 24, 2005
    3,052
    swapping the res would be fine with me,I cant remeber now but do the brackets screw into the pump body instead of the res ?
  6. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    The brackets should mount to the holes in the front of the pump body and/or the stud(s) on back of the pump that hold the reservoir on. All of the pumps that I have fooled with have had the same bolt holes in them, just different combinations used for different brackets.
    Russ
  7. 1-tonmudder
    Apr 24, 2005
    3,052
    Thanks,it will be monday before I can try it,but Ill let you know if it works.
  8. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Any pics of changing the reservoirs out? I think I might have to try it. Of the 3 pumps I have, they all seem clocked a little different. If its easy to change around, I'll go get a HB reservoir and stop using the "T."
  9. sandawgk5
    Oct 28, 2003
    6,881
    Yep pull the fitting and the 2 bolts off the back of the rez and pull the pump out. It is a tight fit as the pump has an oring that surrounds it to seal the front to the rez and each hole on the rear has an oring to seal it all are located on the pump.
    Ira
  10. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Sorry, I don't have any pictures and I just threw away all the extra pumps I had last week. Like Ira said though, it is just a matter of taking the pump fitting and 2 bolts/stud off the back. I usually put the pump housing in a vise and try and tap the reservoir away from the pump. Sometimes they are a fairly tight fit and you may bend the reservoir a little getting it off, but you can straighten it back out once it is off. I have had to do that a few times and never had a problem with it sealing.
    Russ
  11. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    The pumps create different pressures too. The hydroboost has a higher pressure.
  12. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I have heard that also, but then from talking to the folks at PSC and from comparing part numbers I have not been able to find a difference in the two pumps. There very possibly is, just not that I have been able to find. I have interchanged pumps also from hydroboost to non-hydroboost with absolutely no difference in the way they performed.
    Russ
  13. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I think its just the pressure valve, or bleeder valve or something like that. The part where the pressure hose screws into is different. But I agree, all internals are the same.
  14. sandawgk5
    Oct 28, 2003
    6,881
    I think the clocking of the holes on the back of the rez are different cause when I put a HB pump from a diesel on my 350 bracket I had to modify it cause the rez hit the bracket. I think that is where my leak is from it appears that the pump is starting to pull out of the rez? The seam of the rez is stuck and when I tightened down the bracket it pulled the pump out a little:doah: .
    Ira
  15. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Ira,
    I apologize for the off topic post, but I noticed in another post you said you live across the street from Gear Vendors. I lived at 1434 Roxanne when I was stationed out there. It is off of Pepper Drive across from Gear Vendors.
    Russ
  16. sandawgk5
    Oct 28, 2003
    6,881
    I live in Pepper Drive Estates right on Graves. I live next to the Storage place on Pepper Drive:D .
    Ira
