Hydroboost Swap....which pump did you use?
Discussion in 'The Garage' started by dhdescender, Apr 5, 2004.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I've swapped in hydroboost recently, and the Chev pump fromt the diesel doesn't match up AT ALL to a caddy block /forums/images/graemlins/angryfire.gif
    I can make a bracket, but its still pretty sketchy. Anyone have any idea if the stock Caddilac pump will be able to keep up with the hydroboost? What if I do the mod's listed on WTO?
    Thanks!
    -Kyle.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    [/ QUOTE ] Hydroboost does not like pumps with the mod.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    see if you can find out the pressure on one of those. i forget what the pressure is suposed to be on a hydroboost pump but its highre than normal. alsthough ive seen several people use a normal chevy pump.
    why would it not like the mods?
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Because it's not designed for the higher pressure/flow. If you have the mods you will notice a pulsation in the pedal when trying to hold your self on an incline. It will also puslate when getting on the brakes hard. I got around it by running a bone stock pump to the hydroboost and an aftermarket KRC pump to the steering.
  5. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    stock caddy pump puts out 750 psi...(Ididnt think it had three ports...does it?) chev hydroboost about 1100... the best way is to adapt the chevy pump by building/modifying the bracket... I did the bracket deal...
    good luck
    cam
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, the flow mod seems to have had no effect on mine. I've had no pulsing problems at all. Slow steering when on the brakes I got, pulsing, haven't noticed it... I'll be using a split system soon (if I can get some projects finished) to aleviate the slow steering problem (I've finally got all the parts).
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Did you do flow and pressure mods or just flow mods? I noticed it after doing pressure mods...
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Just flow. I have all the power I could want, it's flow I'm hurting on with a 2" ram plus Hydroboost. /forums/images/graemlins/frown.gif
  9. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah my 2.25" ram moves as fast as I can turn the wheel, the KRC pumps are where it's at. Then again I have a 1.5" shaft in there... The volume calcs workout to a 1.8" bore ram with 5/8" shaft or something like that.
  10. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i picked up a bracket and pump off an m1008 now i just gotta figure out how to sawp that tp my 350. maybe not the bracket but at least the pump.
    69k5
  11. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Jason do you have any pics of that KRC pump mounted up? I am very interested in that /forums/images/graemlins/waytogo.gif
    Chris
  12. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    I could not make the brackets off my M1008 work on the small block. I obtained the brackets and pump off a step van ("bread truck", Chevy calls it a P model, I think) with hydro boost and a small block. The pump, unfortunately, was toast but the brackets worked with the M1008 pump after a little bit of grinding. The M1008 pump's reservoir was a bit wider and I had to grind out a slight "V" in the bracket in order to bolt the pump to it.
    I had WTO do the mods to the pump and have noticed no pulsation.
    Ronnie /forums/images/graemlins/truck.gif
  13. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Dumb question: What is WTO? Or what is the web address? /forums/images/graemlins/confused.gif
  14. dhdescender
    Aug 10, 2002
    628
  15. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Sure thing boss:
    The stock pump used to be down where the KRC pump is now.
  16. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Very cool..so you just mounted the KRC pump to a plate and welded the plate where the old PS pump was? Nice...I may have to do that...I have a KRC pump laying around from another project...I think that may be the hot ticket for the hydraulic assist here this spring /forums/images/graemlins/waytogo.gif
    Chris
  17. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks for the tip. I hadnt thought about any p vans. I had looked at the m1008 bracket and it didnt look promising so i was looking at modifying the 350 one. ill check it out this weekend. if all else fails ill look for a jy with a bread truck.
    69k5
  18. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    Do you know how much pressure and volume the KRC pump puts out?
    Also, does anyone know how much volume a stock hydroboost pump puts out? It was stated earlier that it puts out 1100psi, but I am interested in gal/min. also.
  19. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    From discussions I have had with Matt at WTO and Jeff at Howe, the most that can be squeezed from a stock p-pump with just the flow mods and stock internals is about 1.1 gpm. But it's more like .8 or so on average. The KRC unit has a pressure of 1450 psi and the flow is adjustable from 2 gpm to 3.7 gpm. I run the 2.8 gpm valve in mine and it's perfect for my setup. I had the 3.7 gpm valve in it and it was too sensitive. This is with a 2.25" double ended ram.
  20. BigRed89
    Oct 28, 2002
    223
    Los Angeles, CA
    Are you saying that the steering was too sensitive, as in you barely turn the steering wheel and the wheels would react? Also, I may have missed this, but how come you didn't just use the KRC pump exclusively instead of using the stock and KRC pump?
