hydroboost without power steering?
Discussion in 'The Garage' started by k204dr, May 15, 2006.
  1. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    is it possible to run hydroboost without having power steering? what would you do with the pressure line coming out of it, could it be tee'd into the return at the pump? I'm doing a brake swap on a fj40, and want to put on hydro, but don't have the time to do a p/s conversion right now.
  2. dremu
    Feb 27, 2000
    15,952
    442
    East of San Francisco
    Took me a minute to realize you mean with a power steering PUMP -- sort of important! -- but without a power steering BOX! :D
    Don't see why you couldn't just block the pressure line coming out; teeing it into the return line seems like it'd drop the pressure going into the hydroboost.
    -- A
  3. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    You'd have to plug the supply from the brake booster to the gear box. That's a high pressure line and you wouldn't want to just tee it in to the return. I wouldn't think you could get the hose clamps on the return lines to hold.
  4. k204dr
    Aug 27, 2004
    463
    TN
    well, guess i need to figure out where to get a plug then. its just for a month or two, then i can get on the power steering conversion.
  5. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Any shop that sells hydraulic equipment and parts should be able to supply one.
