hydroboost: ya or nay?
Discussion in 'The Garage' started by RGV72BLAZER, Apr 3, 2007.
  1. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    debating on whether to run a hydroboost setup. any thoughts. i'll be running front discs and rear drums for now, but i think i could use the extra stopping power, especially w/44s. let me know what you think & what all i would need to complete this setup. thanks.
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I love hydraboost. I think stock GM brakes are adequate, but, they are prone to failure (like just not working with full power, or no power to the rears).
    You'll need the lines, and a PS pump. I think thats about it.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    mastercyliner as well. its night and say, especically with 4wheel disc's (if you eventually go with rear disc)
  4. RGV72BLAZER
    Jan 23, 2006
    2,425
    thanks. :)
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    My blazer stops like a car with the hydroboost. I had to hit em one day and I was worried about being rearended, not rearending.
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    what if you have hydro assist also? Does it still work good?
  7. RGV72BLAZER
    Jan 23, 2006
    2,425
    X2 :confused:
  8. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Im pretty sure that if you do that, then you will have pressure problems, as the pump wasnt designed for operating three fluid hungry sytems.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I run HB with Assist and do not have any problems so far. I run a welded front also. I have modded my pump for flow and pressure but other than that it is a stock GM pump.
    Ira
  10. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm very impressed with the hydroboost system I put on my 69 K20. It had manual brakes before the swap so of course the improvement was huge.
    If you can find a parts truck, you could grab it's complete system (power steering pump, the lines and the master cylinder setup. I made a reinforcement plate for my firewall since the setup is kind of heavy. For the brake pedal connection I cut the rod and then put an all-thread clevis end on it to attach it to the stock brake pedal. My website in my sig has an section specifically on the hydroboost swap.
