Hydroboost
Discussion in 'The Garage' started by mudjunkie 82, Apr 17, 2005.
  1. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    cannot get this damn thing to work right, Bleed the lines several times, sometimes the brakes will work, other times they will not???? master cylinder is new, Any Suggestions for setting Hydroboost up??????
  2. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Did you look into reseting the Prssure differential valve?
    Or did you start bleeding at the furthest most bleeder valve, passenger rear, driver rear, passenger, driver, in that order?
  3. dark eternal
    dark eternal Registered Member
    Jan 15, 2004
    22
    Dallas, Tx
    did you bench bleed the MC
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Hydroboost does not need any special bleeding functions. Its autopurging into the Power steering supply. If your having trouble, it might be something else.
  5. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    tried that,bleed and pedal still goes to the floor??????? :confused:
  6. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    Are you using all the hydroboost parts. I'm doing the same thing to my sub. When I had all the parts out and ready to go back in I noticed that the brake pedal arm and actuator rod for the hydro are specific to that set up, the hole for the rod was in a different spot. Just a thought.
  7. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    i dont have hydroboost, but when i did a rear disc brake conv. on my 70' truck i put a rebuilt master on that was large capasity for disc brakes,and could not get peddle for nothing. i bench blead the master, used a power bleeder you name it, nothing worked. than a buddy that has a street rod shop said throw that rebuilt master away and buy a new one, said rebuilts are junk, when for a few bucks more you can get a new one. sure enough that was the problem, got peddle easy has worked great ever since. my buddy couldnt show me proof it was bad, he just said "trust me". he just had that same problem on several rods they did conversions on, hydroboost and brakebooster type systems. he stoped buying rebuilts and there problem was solved. hope that might help.
  8. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
  9. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    there is in the gm service book. its for getting the air out when the system is opened up.
    and when i changed over from vac brakes to hydro the pedel setup was o.k. on my truck. just get all the parts like the hoses and the pump.
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I might be wrong, but I believe the procedure was something like add fluid, hit brakes, turn wheel, etc etc add more fluid- Basically its the same as trying to bleed a power steering pump!
  11. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    That's NOT an autozone crap master...is it???
    I had a problem...with one of there junk masters...a year ago. :mad:
    Good to see that you got that rig moving. :cool1:
