hydrobooster leak help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tp85, Jun 27, 2005.
  1. tp85
    tp85 1/2 ton status Premium Member
    Mar 14, 2002
    130
    Maryland
    Hi guys,
    It seems my hydrobooster is leaking power steering fluid. I tried to find the search function on the board to no avail.
    Could someone please tell me what my options are? Are there o-rings/seals etc. that can leak, or does this normally require replacing the hydrobooster unit? Do you guys have the procedure documented somewhere? Do I have to break open the brake system...needing to bleed the ABS unit and brake lines?
    1994 K2500 Suburban
    Thanks for your help.
    Tom
