Hydrolic sm465 ? slave type
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JohnSPledg, Apr 5, 2002.
  1. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    I know its been asked a couple hundred times, but I can't seem to find all the information. I have a 1972 sm465/np205 combo. I have a 350 engine on the way, but not sure what year the block is or if it matters. I want to convert to hydrolic clutch with slave cylinder. What bellhousing, shift fork, master, push rod, etc. works best. I would prefer to pull everything from one truck and keep it all gm parts for ease of replacement. I have searched the message boards and can't seem to find the answer for a complete set up, they all seem to be people starting off with a handfull of parts and going from there. I have NOTHING but pieces of the stock linkage. It had been severely "rigged" when I bought it. But I was younger and stupider then. Also, any first gen people in the Baton Rouge, La area? Or in "Funroe" who can get me a skyjacker hook up to replace my 6" block lift? BTW i'm not driving it with the block lift, I parked it in 1996 when I burned through 6 qts of 20w-60 in less than 100 miles. Thanks in advance for the help. I am tired of looking at this thing sit in my carport. I'm ready to get it back out in the mud.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The hydraulic clutch linkage came on 1985 and later GM trucks...I got my pedal assembly, bellhousing, slave/master cylinders, shift fork and boots, all of an 1985 K5 with a 6.2L Diesel...I had to order a new slave cylinder, shift fork, and shift-fork stud cuz they were kinda shot... Here are a few part #'s that I needed...
    --Clutch release fork -#15592270
    --Slave cylinder -#15615868
    --Hydraulic hose- #15537760
    --Bell Housing-#15530202
    --Pivot; clutch fork-#15592268
    --Master cylinder-#15615867
    Othere than those parts, all you will need is a clutch pedal assembly, a few push rods, seals...Oh and while you are at it, put a new clutch in and resurface the flywheel...
    Chris
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    You can use the stock bellhousing and fork with a Fiero's hydraulic slave cylinder if you fabricate a mount for it. I actually have a mount for one floating around here somewhere, but I don't know where it is.
  4. lukefalls
    lukefalls 1/2 ton status
    May 21, 2002
    163
    Fairbankks, AK
    how well does that setup work? I want to conver mine too, but I am not sure what to do
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you have to remove all that mechanicallinkage and find a place to put in the master cylinder, thats; the hard part. especially if you don't like cuttingup your blaze.
    i used the hole where the clutch rod goes to teh outside, but i have an extra 2" of clearance cause my body lift. so i wont hit the valve cover.
    next you need to get a new bellhousing and shift fork that accepts the slave cylinder, or just fab a braket and used the existing stuff.
    then route the hyd lines and you're set. if you use DOT3 brake fluid MAKE SURE you use DOT3 approved hoses, that means it has to be brake fluid proff.
    ARQ.
  6. lukefalls
    May 21, 2002
    163
    Fairbankks, AK
    I'll give 'er a go. Thanks
