I am getting tired of this no spark issue
Discussion in 'The Garage' started by Sample, Dec 27, 2002.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    I have an '83 K5 w/ 350. It has an HEI distributor. I cannot get even one weak spark out of it. I am on my 3rd full distributor. 3 caps, 3 rotors, 2 coils, 4 modules, 3 pick ups. I have 12v going in, I even jumpered straight from the battery. The rotor stops in the same place every time when put to TDC, so the timing belt should be good.
    It is originally a 5 pin distributor, but I believe the 4 pin ones will work in there too.
    Any ideas?
    Thanks,
    Chris
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Just a needle in the hay, but is everything grounded? THat's where I'd check first. (from the coil)
  3. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    You mean the little metal tab that bolts under the coil? Or the black wire coming off the coil? Both are bolted down. Are there any other grounds that I may be missing?
    Thanks a ton,
    Chris
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    UH OH.... I hope you haven't done what I did...
    I went through this for a FULL day.
    First, when did you run the HEI, has it been running before?
    What did you do? Did you take the distributor apart and "rebuild it". That's what I did.
    And I - put the drive gear on UPSIDE DOWN! Yep, upside down! /forums/images/graemlins/ooo.gif
    I found it would go in, meet the oil shaft and line-up, the rotor wouldn't even turn. SO I figured all is good.
    Take the disributor out, and hook it up to 12 volts and a ground, does it fire?
    Check your cam gear driveshaft gearing with another and make sure it's not upside down like mine was
    Good luck.
  5. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    YEP, that's what gave me the idea that FOR SOME G*D D**N REASON IT wasn't rotating.
    Good luck.
  6. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    is your engine to frame, frame to battery ground good?
    John
