I am in a jam, any ideas
Discussion in 'The Garage' started by ktedesco, May 2, 2004.
  1. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    Interesting day on the trail today. Made a trip up to a trail west of Denver (2hrs away) to do some wheeling. My rear 10b decided it had enough of this wheeling stuff. Anyway, I blew up my rear diff along with the rear driver side axle shaft. Now my truck is sitting up on a trail and I had to get a ride 2 hrs to my house (thanks firefighter184 /forums/images/graemlins/thumb.gif). Any ideas how to get it off the trail. I have to go about 5 miles (90% easy dirt 10% mild rocks). I am thinking my best bet is too disconnect the rear driveshaft, plug the np241, and drive out in front wheel drive. My question is, how can I keep the axle from sliding out. Is my only solution to drive a couple hundred yards, lift truck, push wheel/axle back in. It will take forever! I only need to get it off the trail and closer to the road for a tow truck. Please /forums/images/graemlins/1zhelp.gif, any ideas!
    Also, whatever damage may result to the rest of the 10b doesn't matter. I have a 14bff in the garage, almost ready to go on the truck.
  2. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    No chance of another truck pulling you out to a tow truck?, I supose it depends on the trail. Goodluck.
  3. ktedesco
    Mar 21, 2004
    365
    I can get the tug from another truck but I am worried about the axle shaft not staying in. Burblover is going to be in the area tomorrow and he offered to give me a hand so we will have his K5 as well as my DD (Honda Passport-don't laugh, its a daily driver)
  4. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
    OMG Kevin, I can't believe that happened (well, actually I can, I blew up my 10 bolt about 2 years ago...of course that's before I found this site /forums/images/graemlins/doah.gif, So I had it rebuilt) What were you trying to do? too much fun pedal? I don't know where youu live, but I'm sure it's close enough, so if you need some help, I'm up for it /forums/images/graemlins/thumb.gif. I'm sick of dealing with my own trucks problems, probably a good change of pace to deal with someone else's /forums/images/graemlins/waytogo.gif
    p.s. who was driving the truck? /forums/images/graemlins/whistling.gif
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Ghetto-ass trail fix #342:
    How to keep axle in when you snap a semi-floating shaft-
    Cut yerself a log abouts 6-8 feet long and about 4 inches in diameter. Set her against the tire about half way up. Take a section of rope an' cut it in half. Lash one end of that there log to your rear bumper and de other end to one of yer steps er door handle somehow. Make it real ghetto-ass. Now, when you's drivin down the road, that log'll hold yer axle in real good like. Rub on your tire like a sumbitch, but it'll get ya out, promise. /forums/images/graemlins/wink.gif
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    id just leave the drive-line in and have him follow behind you and watch very closely the rear tire and if it starts walking out jack it up and push it back in /forums/images/graemlins/thumb.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Why not just do a trail repair and replace the broken axle then drive it out and home?
  8. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    How bad is the axle? Is it trying to walk out of the housing? Anyway to get stock truck to where you are on the trail? How about a truck and trailer? Where is the trail?
  9. ktedesco
    Mar 21, 2004
    365
    Hey Nick, I think some of your recent bad luck rubbed off on me. I heard about your truck. My truck is up on Kenosha Pass. I let them know at work that I need to go recover it, luckly my platoon sergeant is a wheeler and understands!
    I wish I could pawn the blame on Kelly, but I have to confess, I was the one pushing the skinny pedal /forums/images/graemlins/doah.gif
  10. ktedesco
    Mar 21, 2004
    365
    You can get to the truck if you are careful with a stock truck. I don't think there would be very many places to get a trailer turned around. I would do a trail repair but I don't know since the diff is grenaded.
    James, yea, the axle is walking out quite a bit.
  11. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    If you replace the broken axle and C-clips, remove the pinion gear, and rear drive shaft; you should be able to drive it out then with the front differential. You might get lucky and not have to remove the pinion gear. Try it with out removing the pinion gear first. It will make the whole situation easier to deal with.
  12. ktedesco
    Mar 21, 2004
    365
    BTW, This is my first trail breakage other than a few u-joints. Does this make me official? (or SOL!)
  13. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    You could try one of those little U-Haul car dollies. If you have a set of stock size tires and rims to put on the back, then back of your truck might fit on one of those.
  14. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    You could pick up a 10B from a junkyard and replace the broken one. Shouldn't take more than 30 mins and $50 to do the swap.
  15. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    just pull out the shaft and tire and let the brakes ans the housing ride on the ground.? /forums/images/graemlins/thinking.gif
  16. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    what 4x4 High said only X 10
    You get my AMEN !!!!!!
    2 pieces of plywood and 2 jack stands
    mabe a adapter u joint
    and 2 guys and a 6 wrenches and 1 hour lattler
    your driving
    get home & go 3 / 4 ton as long as your doing it might as well do it right
  17. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I vote for trail repair too.
    Get yourself a few 10 bolt parts and go fix it. There has to be someone in your area with a carrier, c-clips, and axleshafts that you could either buy or borrow. Pop the cover off and see what the carnage is. Really it sounds like you need an axleshaft and some way to hold it in the axle...ie the carrier, spiders and c-clips.
    Pull the rear shaft and make sure the ring and pinion are not going to lock up on you (assuming that is what you grenaded). Drive it out of the there on the front shaft. /forums/images/graemlins/waytogo.gif
  18. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Kevin, how did you make out with this?
  19. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    How come nobody mentiond the handy mans secret weapon.
    Duck tape the bitch in /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    and if that doesent work i think the trail repair is a good option /forums/images/graemlins/thumb.gif
  20. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    well did you get it back home?
