I am looking at how to install dual batteries and have an idea........
Discussion in 'The Garage' started by justwhatido, Jun 25, 2004.
  1. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Why not use a marine isolator/switch. After all boats have been using dual batteries for years. Marine equipment should be more resistent to effects of H2O than most automotive stuff.
    Anyone tried marine systems.
    /forums/images/graemlins/pimp1.gif
    Fred
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i run one of these in my Chevelle. pretty sure Tweety runs something similar in his rig...
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I just wired mine together.
  4. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    I have the Perco also.
  5. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    I"ve got a selector switch mounted in the drivers side inner front fender. Both are hot or I can switch to one. Keep it for reserve while camping, etc. Less choices than a Perko but it works.
  6. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Any links on this?
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thats what im planning on using. i think their like $26
  8. lrmccain
    lrmccain Registered Member
    May 29, 2004
    11
    hey, try an RV store, they have a setup that I have for like 75-100 bucks that will charge both your batteries all the time but will draw off of either one, or both... depending on where you select. This system works great, alternator goes and you can just switch to the other batt and get back to civilization /forums/images/graemlins/thumb.gif
  9. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i know this link has been posted up a few other times, but it is the heat...
    hellroaring
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
  11. justwhatido
    Apr 8, 2004
    1,037
    Mobile, AL
    The Perko selector switch was exactly what I had in mind. I thought that a marine fuse block with half a dozen terminals would more than handle the aux lights, winch, CB and kicker, ect and keep things far neater than just tying to battery terminals. Anyone tried the marine fuse blocks (or even a breaker panel?) /forums/images/graemlins/pimp1.gif Fred
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  13. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    NoT the winch ! /forums/images/graemlins/confused.gif
  14. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I use the new NW WRANGLER switch. It's really small and neat! /forums/images/graemlins/thumb.gif
  15. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Here is mine. The stock solenoid wires reached the present location. I used a 60 amp C/B to replace the fusible links.
