I am missing something here....
Discussion in 'The Garage' started by Moody, Oct 15, 2006.
  1. Moody
    Moody 1/2 ton status
    Aug 4, 2005
    232
    Yakima, WA
    Okay, I been working on my front end this week trying to get it ready to upgrade my 70 blazer to 3/4 ton running gear. Everything was going fine, removed the brakes, spindles, axle shafts, etc. Went down to Autozone and rented the ball joint removal tool and was planning on installing all new moog ball joints today. Wrong! I spent all day just trying to get the knuckles off! Upper castle nut and threaded collar came right off...removed the lower nut and lower snap ring. I cannot get the the lower end of the knuckle to separate from the axle. I tried a BFH with a picklefork, soaking in PB.....it won't budge. The only thing I haven't tried is the torch. Am I missing something here or should it be this hard?:doah:
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    ...I must be missing something. I was under the impression that putting 3/4 diffs under a K5 involved removeing ubolts.....dropping crappy diffs......slining up better diffs.....install new ubolts........:confused:
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Not on the front. You just need to swap outters to 8 lug.
    8 lug hubs/rotors and backing plates.
  4. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    oh I see.....not haveing a complete set of 3/4ton diffs would do that then 'eh.
  5. Moody
    Aug 4, 2005
    232
    Yakima, WA
    I guess I should clarify, I have been tearing down my 8 lug dana 44...going to install all new ball joints, bearings, brakes, etc bearing swapping out the crappy axle for the new axle:))
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Just hit downward on the knuckle until it breaks loose. Or just keep trying ball joint tools, like the pickle fork or the separator. One thing I can tell you, is that you really can't be pussyfootin around with it. Get after it like you're serious, get a bigger hammer, whatever it takes. If you think heat would help, try it, but I've never needed it. Both ball joints should pop loose at the taper and the knuckle should drop free. So no, you're not missing anything.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    x eleventeen
  8. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    ... and swing it like a man.
  9. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    .....or you can get a ball joint separator. I have on in the garage you can borrow. its not a pickle fork, its a small press specifically designed to grab the ball joint. it was pretty cheap, at Princess Auto........our version of HF.
  10. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    hit it on the side of the lower part of the inner C. Really hard! I wailed on mine, got tired and soaked it in PB. went and had a sandwich. when I came back it fell out on the first swing. Good luck.
  11. Moody
    Aug 4, 2005
    232
    Yakima, WA
    Thanks for all the feedback! So the general opinion appears to be quit being a "girly man" and "git' er done":))) I've been using a seven pound sledge but I'm going to try the torch on it tonight. Demon, I tried using the ball joint press..no luck.
  12. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Well thats your problem you need at least a 10lb sledge. I'd step up to the bar and get a 15lb sledge. Just need to cut off 1/2 of the handle. Now that is a BFH :p: :p: :grin:
