I am pissed...help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Mar 25, 2002.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    OK finally got the truck back on the road...and drive it for a couple of weeks . Well today I push it and run out of gas ( late to work ). I hike to the gas station get gas and fill my empty tank up with 2 gallons of gas....Well to compound the problem My engine was knocking like all hell and that is in my head. Well the truck wouldn't start. Just kept rolling over and over...A fellow blazer owner stops and wants to ask me a couple of questions about my 3/4 ton axles and offers to tow me to the gas station. So we go to the gas station and fill up about 8 gallons. Still no start and then my starter sticks and won't stop even with my keys out of the ignition! we finally unhook the neg battery terminal and he tows me to my work where we chat about blazers for a couple of minutes.....Thanks D !
    I gave him the website so I am sure we will have another member soon!
    Anyway any takes on my situation?
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Fuel pump?
    rene
  3. Like tRusty said, and maybe fuel pump relay or sending unit.
  4. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    If you sucked it dry, All the crap in the bottom of the tank can plug the filter. Thats where I would start.
  5. bigblue
    Dec 6, 2000
    658
    southern california
    Yeah, I will start there damn it just doesn't seem to stop...
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    disconnect the fuel return line up in the engine. turn the key and see if any squirts out. then you'll know if you're getting gas there. usually when you "wait" till your gas runs out, the crud on the bottom will be picked up and sent out the fuel line. if your filter is good the injectors won't pick it up.
    as for the starter, you probably fried the solenoid(part on top of the starter), tap it a few times with something and connect the batt, if the engine cranks still, time for a new starter solenoid. taping the solenoid it usually disengages it.
    ARQ.
  7. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Those fuel pumps don't like to run dry, may have burned it up. - Doug
  8. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    Ditto...electric fuel pump + no fuel for lubrication/cooling = BAD
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    If you have a TBI, i will bet this weeks allowance from the GF that it is the fuel pump. I had a little s-10 years ago, and i burned the fuel pump in about 5 minutes. Warrenty was still good on it, but the guy i talked to said it was a common occurance.
  10. bigblue
    Dec 6, 2000
    658
    southern california
    Changin that fuel pump out is no walk in the park either....I am going to do what arq said and see if I am getting fuel to the engine...
  11. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    just make sure you put a small container at the open end, ya don't wanna burn it if the gas lights up...
    ARQ.
  12. I just changed out my fuel pump about a month ago. A real PITA with my huge 37 gal tank. Be prepared for some fun if it has never been changed on your Blazer. The factory seals the sending unit with this black stuff that does not come off very easy. Also, if you do change it out change the screen (about $5) and fuel filter.
  13. bigblue
    Dec 6, 2000
    658
    southern california
    Oh, it was changed 2 years ago..here we go again!
  14. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    just for shits and giggles check your spark too. I went crazy replacing a fuel pump (old style) and ended up changing out the module on my distributor
  15. bigblue
    Dec 6, 2000
    658
    southern california
    It was weird...Now that I think about it..it fired up right off the bat then shut off almost immediately. Then rolled over and over....
  16. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    did you check your blinker fluid....
    ARQ.
  17. bigblue
    Dec 6, 2000
    658
    southern california
    very funny hahha very funny...hehe
  18. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Hey blue... try banging on the fuel tank with a hammer while someone cranks it. A lot of times that is enough to get the pump kicking if that is the case. If it works I would try starting it a bunch of times and see if the no start condition returns, if it does replace the pump. If not... let it buck till the problme returns. good luck
  19. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    don't laugh stuff like that works. good advice.
  20. hoserr
    hoserr Registered Member
    Jul 25, 2001
    78
    chula vista, ca
    i've gone through several fuel pumps an' it sucks. can you use an aftermarket pump on the outside? by pass the pump inside? it makes it easy to repair on the trail also. i have a pair of 'em mounted side by side an use a fuel pressures gage in the engine to tell when the pump goes south, which seems to happen often. on the starter, hope aboot picking one up at the kragen's, pep boys, etc. down the street, install it an use yours as a spare once it's fixed?
