I am SO frustrated
Discussion in 'The Garage' started by BlackDog714, Dec 16, 2004.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    I am SO frustrated UPDATE!!!
    OK, I cant figure this thing out. I swapped in a 92 K code TBI into my 85 K5. I used a Painless Wiring 60101 harness. Everything is hooked up, no apparent vacuum leaks, no fuel leaks, fuel is being injected and I am getting spark but the damn thing WONT F**KING start. All I get is random sputtering. I have tried to retime it. I bumped it over until I got a good puff of air from #1 and lined up the timing mark, followed the proper firing order and still nothing but random firing...
    Any ideas? :mad:
  2. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    when we installed a 350 into a friends 1994 s10 , we had a similar problem.
    it would get fuel right at the begining whish is what you might be seeing.
    this is called the priming stage. but it wouldnt start.
    he had one of the wires wrong that went to the fuel pump relay, which is what is needed to work to continue fuel flow.
    i guess make sure you are getting fuel after the initial priming , maybe thats your problem. good luck
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Ditto the fuel thing. Try spraying ether (easy start we call it here) into the throttle body as you're buddy is cranking the motor. If it burst into life for a second or two it's a fuel thing. If it still just fires ramdomly you've got other probs like maybe spark lead order, vacuum leaks, timing...etc
    Good luck.
    I'm thinking of using that Painless kit. Is it good? Easy to use and covers everything??
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Distributor 180* out or way off? Sounds to me like a timing issue.
  5. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Yeah, it was a great kit. The manual is a little scattered, but the support is great when you call.
  6. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    I had a issue with a buddies jeep that I done the sbc/fi swap to about a year and half ago. Ran good thru summer then on the coldest day of the year went out to fire it for work and it wouldn't run. I looked high and low when I got back from my regular job. Found the problem to be in the map sensor. Unpluged it engine fired right up. Had somehow shorted internal and was killing the signal to the distributor.
  7. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Update
    Ok, so I put the compression tester on and rolled it over to TDC on the compression stroke. Well it still wouldnt fire up, so I put a little throttle input and viola, it started to run. It ran like crap at first, then smoothed right out. My biggest problem now is that it wont idle. How do you adjust the idle on a TBI???? :confused:
  8. BlackDog714
    Jun 8, 2002
    260
    Indiana
    I did this, and nothing changed until I did the above...
  9. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Does no one know?
  10. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    the plug for the factory TBI adjustment is plugged up in the right front side, next to the throttle... not sure if they're leaded closed or what, didn't look at it too close. my new CFM tech throttle body has the screw exposed for adjustment.
    can't find the link i had to the article about removing the plug.. maybe someone will post it up.
  11. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Is it odd that its not idling??? I thought that was one of the great things about TBI???
  12. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    i'm by no means an expert in TBI, just got into it a few months ago... someone correct me if i'm wrong please..
    yes, that does sound slightly unusual to me. most probs i hear about are the opposite, in that it idles too high, which usually is attributed to a vacuum leak...
    if its just falling off to a stall, i'd be guessing at the issue.. i did have a bad IAC act like that on a car i had once.. if i understand correctly, you had to pedal it to get it going? that was another symptom that bad IAC had...
  13. dyeager535
    26,977
    Hit thirdgen.org's tech article section up. There is a bit in there about adjusting IAC and TPS.
    I believe it applies to TBI as well as TPI.
  14. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Exactly...
