i am stuck, can someone please help w/brakes
Discussion in 'The Garage' started by leakinposchevy1988, May 27, 2005.
  1. leakinposchevy1988
    leakinposchevy1988 Newbie
    May 27, 2005
    folsom
    i got this truck its a 88 z71 with jacked up brakes! it only stopes in the rear, i bled the whole system (had the combination pin blocked) it gained a little pressure but when i start the car i can press the brake and the idle changes, and it goes 1/2 way to the floor.
    i dont know how to use these forum this ill check back in a little while.
    thanks jeff
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Do you hear a sound like whistling air or running water? Bet you have a bad brake booster if you do.
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    have someone watch the master with cap off to see if it spits fluid up when the pedel is pushed. and it sounds like master.dont forget the frt section is rear and the back is frt.
