I am thinking of dremeling out the flapper in the heat riser.
Discussion in 'The Garage' started by Scott A, Jun 28, 2004.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    I am not sure it is working corectly and I don't want any restrictions. I would cut on the green line. Anything wrong with doing that??
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Nothing wrong but they sell a blank spacer just for this situation.
  3. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    Oh yeah where, Autozone? I wonder how much they get for one?
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Check with your local muffler shop. You won't be able to beat the free price of removing the flapper in yours though. /forums/images/graemlins/thumb.gif
  5. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    I have cut them out and put bolts in the holes where the shaft was,or brazed them shut--your motor will take longer to warm up without it,may lead to carb icing in the winter if it gets cold where you are.I dont think you will gain much by removing it--when they fail the vacuum canister has a spring that holds the butterfly in the open posistion,doesnt create much back pressure.If you must remove it,you can look for the blank spacer as posted,or you may be able to bolt the pipe on directly to the manifold with shorter studs,but many times the spacer has a flare cast into it for the pipe's flange,and wont work without it. /forums/images/graemlins/crazy.gif
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do you need it for visual inspection ? I didn't, muffler shop removed it when I axed the stock pipes. If you are in Southern Cali ( don't know Monrovia , where is it ? ) you won't notice it gone. /forums/images/graemlins/k5.gif
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Its called Tampering, and its a Federal offense
    just don't get caught ! /forums/images/graemlins/screwy.gif
  8. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    yeah, that flapper eliminates ALL of the emissions of the engine......hmmm, and bigger tires make you smarter.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah, and it affects your balljoint preload. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
