I bring the Bling... serious question too
Discussion in 'The Garage' started by Confedneck79K30, Jan 1, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    so i brought home some hd wheels for my 79, and put them on the front since the rf was flat anyways...
    so sexy... anyways, what kinda hubs are those? factory spicer?
    does the "hungary" mean they are aftermarket??
    and wtf are those rings for??
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Need closeup of hub... should say spicer right on it though
    The rims are factory, possibly made in hungary...(outsourcing:rolleyes:)
    And the rings i believe are spacers... were they in between the set of rear rims?
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    no, they were on the outside of the front rims, see that rust ring on the wheel? thats where that ring sat and the lugnuts ran up against the flat ring... the hubs dont say anything on them, the dials are chunked a little but the hubs do work, so ill leave them for now, just wondering...
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the rims are GM. the rings are for a dually application. if you look on the rims they are pictured with the rims do not have a tapered seat for the lugnuts.
  5. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    What size tires are those? How tall are they? I may be looking for a set of those for my tow rig.
  6. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    which tires? the duallys?
  7. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    no the new ones.
  8. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    heck i think 245 75r16
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Snap a close up shot of the lockouts......can't see them from that far.
    Those rings are normal on dually rims. The DRW K30 at my shop has them. As stated above, they have tapers on them for the lug nuts as the rims themselves don't.
  10. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ill get a closer pic of the hub, i wonder why they dont taper the wheels?
  11. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    they don't taper the wheels because then you can use them in any position. If they tapered them then 2 would be tapered on the outside for the front. 2 would be tapered on the inside for the outer rears and 2 would have no taper so they sat flush to the hub in the rear and the outer sat flush to it. Get it.
  12. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Can you measure the backspacing on the HD rims while you've got a couple loose still?
  13. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    no problem, ill do it sunday!
  14. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    I love those new hd wheels.
