I broke a tap
Discussion in 'The Garage' started by chvyhs, Feb 25, 2003.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I broke a tap in my output shaft. I'm installing my SLE from Driveshaft super store and it calls for drilling and taping. Well I was doing my last turn before I backed it out and it broke off just below flush. How do I get it out? /forums/images/graemlins/1zhelp.gif
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    my experience with tap and dye sets is, you don't get a tap out. you could try to drill a smaller hole in the end and use an EZ out, but the taps i have messed with are usually to hard to drill. you best shot would probably be to take it to a machine shop
    rick
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I have a set of tap extractors in tool box.Will go tomorrow and see if theres a part # or such on them for you.They basically have four hardened pins that slide into recesses of tap with a sliding collar to reinforce them and usually will back them out.If you know a really good welder you might be able to get them to weld a nut onto tap{weld through center hole of nut}and back it out.LOL /forums/images/graemlins/thumb.gif
  4. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    NICE JOB!!!
    first off what size was the tap, how many flutes on it, do you think you bottomed it out and was it a cheapy?
    1-You need to blow the hole out as best as you can, get all the chips out.
    2-sometimes you can take a smaller tap and tap on the flutes as to unscrew it.
    3-how big is the part, might need to put it in a lathe and carbide it out.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    If it is a pretty big tap, you could try welding on a smaller bolt...oter than that, I don't think you will be able to drill it out with a hand drill to use an EZ-OUT...
    Chris
  6. chvyhs
    Feb 12, 2001
    1,469
    Thanks everyone
    It's a 5/16 tap stuck inside my output shaft.
  7. chvyhs
    Feb 12, 2001
    1,469
    We got it out./forums/images/graemlins/thumb.gif
    Ended up just breaking it out one little piece at a time.
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I know how that goes... ^^^^ They are fairly brittle so its not too hard but its time consuming.
