I can get an np 205
Discussion in 'The Garage' started by keevy, Dec 29, 2004.
  1. keevy
    keevy Registered Member
    Aug 24, 2003
    36
    Belgium
    I can get an np 205 is worth to change it with my stock np 208 in my Chevy
    K5 Blazer 1987
    Thanks a lot
  2. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Good question. 208's must be tougher than they get credit for since Chevy thought it was okay to put them on rigs with TH400, D60, 14Bff, etc. Maybe it's just the aluminum case that's the problem from getting physically hit by boulders - but you can solve that with a skid plate. The slip yoke is not cool either though - wish someone would come up with an easy SYE kit for 208.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    The biggest question will be: "What do you do with your K5?" Like what type of wheeling do you do?
    If the 208 isn't giving you any trouble and you have a skid plate on it, then I wouldn't swap just to have a 205. May not hurt to get it and keep it in the garage incase someday you want to do a doubler.
  4. dyeager535
    26,978
    Also kind of depends what model it is.
    I see what country you are in, if it's a 32 spline input 205, they are pretty hard to find, (even moreso over there I suspect!) if it's a good deal and you plan on keeping your truck, it probably won't hurt to pick it up!
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    208's will take some good heavy offroading as long as you don't let anything hit the aluminum case. The case walls are very thin and even a decent hit from something hard could crack the case.
    I put my 208 threw some pretty heavy use and it has held up just fine for what I do (rockcrawling mostly). It has a better lowrange then a 205 does too.
    Even if it was possible to directly swap a 205 inplace of a 208 (which it isn't even with the right 205) I wouldn't do it. Even if the 205 was free. I like my 208 and I wouldn't loose the lowrange it offers (2.61 vs. 1.96). The 205 may be stronger but its lowrange isn't that good and it is heavier.
    Harley
