I cannot do a burn out
Discussion in 'The Garage' started by BranndonC, Apr 25, 2006.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I tried a front wheel drive burnout.. and my back brakes suck so bad, that i can not get the front to spin, it just drives through the brakes. I'll have to adjust the brakes
  2. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    too much tech:rolleyes:
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I wish I could do a burnout period. maybe I need a 514 caddy for my dd.:D
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Yeah get the tech outta here...:haha:
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I wish a mod would move this. :rolleyes: :p:
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    lol fine. I didn't think this was importand enough for the garage.. Just rambling :)
  7. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Wait, you mean to tell me with all that motor, you can't do a front burnout???? I did one in my 89 with 40s and 3.73s with no brakes. Brakes shouldn't make too much of a difference. I have a big block too, but I know it doesnt have the torque yours does. Did you just mash the pedal and see what happens????
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    this is a very important matter! any k5 with a caddy motor in it doin burnouts definitely deserves truck of the month! even if it cant do front burn outs, id still take it! :)
  9. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    what is the big deal about being able to burn out tires or not ?
    who cares ?
    being able to do it or not al depends on a million different factors and not just your engine output
    axle gearing, tire height, tire type, surface type, and so forth is what are some of the zillions of factors
    from my past experience and observations and after years of ownign billions of different makes and models and types of cars trucks and vans i have found that taller ratio vehicles with shorter tires and weaker engines tend to break loose at a dead stop quicker and easier than those with deeper ratio and stronger engines and/or taller tires
    on pavement anyways
    i have had vehicles with anywhere from 2.28 ratio on up to 6.17
    some are just too deep axle ratio and short of a first gear to break anything loose, while others got so good of traction that they couldnt do it either
    being able to bite and go without spinning is better in my mind than jut sitting and spinning
    you seem to be trying to spin yours off, but you are more likely to break a u joint or something worse and when that happens i will laugh
    bottom line: it cant burn out readily; who cares ? ! ¿
    you posted and you recieved, hehe
    good luck
  10. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    didn't mash it because I was still in the drive way, i'll try that when its sunny out again
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    you need to change your sig to shredder.:haha: :haha: :haha: tires HA i'll kill em.
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I like the nickname!
    What's that sound?
    What is that cloud of smoke on the horizon?
    Shredder!
    :bow: :bow: :bow: :bow: :bow:
  13. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    umm drive through water??
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Billions? :rolleyes:
