I Can't Take It Anymore....
Discussion in 'Pacific Region' started by BlazenHeart, Sep 3, 2002.
  1. BlazenHeart
    BlazenHeart 1/2 ton status
    Mar 22, 2002
    250
    Foothills of the Sierra Nevadas
    I Can\'t Take It Anymore....
    …I need HELP!!!!! My brake light is staying on, speedometer is wigging out and every now & then the service engine light comes on (mostly when going down hill). I had my friend check it out, who works for a Chevy dealer, and he said it was the speed motion sensor. So I got a new one changed it out and that lasted for about 10 minutes. The brake light stayed off for the 10 min but the speedometer was still on the fritz and service engine light still came on. I had this happen before at the beginning of the year changed the part late February and all was well until Sierra Trek.
    Can anyone help on this?? I would greatly appreciate all the help I can get on this, it is really starting to bug the piss out of me.
  2. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Re: I Can\'t Take It Anymore....
    Try the Switch at the top of the break pedal, could be a tired unit.
    Maybe try squrting some oil down the inner speedo cable to lube things up. /forums/images/icons/confused.gif
  3. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    it could be three different problems. or at least two.
    you may have to reset your computer to tell it that the speed sensor has been replaced. it may do this on its own, something to look for.
    the brake light issue is probably its own little issue. start at the pedal, and go towards the light itself, and rule out any shorts or faulty components.
    aren't these trucks fun?
  4. BlazenHeart
    Mar 22, 2002
    250
    I did disconnect the battery cables to reset the computer, that only lasted 10 min if that. I was hoping someone else has had this problem before so I could get some insight.
    And last time I did have this happen replacing the sensor fixed it.
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Take a paper clip, unbend it all out. Then utilizing the two ends, stick each end into the top right hand ports on the ALDL connector that should be located to the left and below the steering column on your dash.
    Now when you do this, you will have to watch your check engine light. Now someone correct me here if I screw things up. It will flash a Code 12. The light will flash once, pause, then two quick flashes. Wait after this, then the fault code will flash. Say it flashes twice, pause, then flashes twic again, that's a Code 22. Retrieve the code and then you will know where to start. You should be able to look up the Codes in a manual, if not, do a search through the tech forums, there are several code lists in posts up there, or just post back. We will fix this, we will overcome.
  6. delta9blazer
    1,646
    it sounds like the friend that works at the chevy dealership did that, to identify the speed sensor.
    i guess she could do it herself, and learn to read code and all.....
