I.D. a Dodge Axle...
Discussion in 'The Garage' started by PsychoticDeadGuy, Dec 4, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    How do i tell a Dodge D60 between a D44. I found a 8 lug dodge axle and it uses studs on the passenger side but it looks to have balljoints. I am all confused about this one. And if it is a d44, is it stronger than my 8lug 10 bolt? It has the same style arm that mounts on the driver side knuckle that GM uses on the 10bolts. It is also a full time axle, there are no selectable hubs. Could this be converted?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    There should be a 60F on the webbing on the front of the axle. Looking at the pic it appears to be the new style ball joint 60 or maybe a 61. No hubs means no good in my book. I think it has the 3 piece axle on the long side. Also the brake calipers sure do look like the 60 calipers I have in the garage.
    Ira
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    so, to buy or not to buy? that is the question? i didnt know they made d61 for the front. how would i do crossover and are the balljoints strong enough to handle 40"+ tires?
  4. sandawgk5
    Oct 28, 2003
    6,881
    I have no experienve with these axles but I say no buy. It has unitized bearings, ball joints, no hubs, not sure if crossover is possible as I cannot tell if the passenger side is flat top, and if it has the axle disconnect inside the housing it is extremely weak.
    Just my .02
    Ira
  5. PsychoticDeadGuy
    Jan 8, 2005
    753
    "it came out of a mid 70's Dodge 3/4 ton 4x4. This is set up for leaf springs not coil springs. Should fit any 70's 80's and maybe some 90's dodge 4x4's."
    "wms looks like 67'' give or take a inch."
    "I want to say its a passanger side drop 8 lug 44, with 4.10s"
    Is this all true? 44? dodge makes no sence whats so ever...67"??
  6. sandawgk5
    Oct 28, 2003
    6,881
    The sure fire way to tell is to look for the 60F or 44F on the webbing down on the lower portion by the cover. If it came from a mid 70s 3/4 ton it is prolly 44 but dodge did some crazy things.
    Ira
  7. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, this is about 2+ hours away from me, but its near my grandparents house, so i guess i will have to go visit them sometime soon.
  8. PsychoticDeadGuy
    Jan 8, 2005
    753
    what else do i look for besides the 60f stamped on the webbing? check for flattops? what else?
  9. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    Looks like a 44 to me. :confused:
  10. sandawgk5
    Oct 28, 2003
    6,881
    The more I look at it the more it looks like a 44. I did not know that 44s had the same bendix style calipers that the dana 60s have.
    Ira
  11. PsychoticDeadGuy
    Jan 8, 2005
    753
    it is really confusing, it has the studs like a GM 60 but it has balljoints like a GM 44....
  12. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    All early dogde's and fullsize IHC had those studs on d-44s.It probably does have flat top knuckles but being full time makes this not a very desireable axle unless it truly is a 60.I cant tell from the pics but the only way to know for sure is the #s or if your good you could tell by sure size.My money is on 44.
  13. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    it's a 44.
  14. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    yep...
  15. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    for the 999time its a 44. full time axle from a dodge. unitized wheelbearings. pass on it to much time to convert and find the stuff to do it with.
